Software: Open building Designer
Hello Himanshu,
In our Schedules, under the wall catalog type you will get all these values. from the Schedules dialog, you can create a custom schedule which will only show the specific property and then export it or else you can export the one already populated in OBD to Excel too. See the below image for reference.
I hope this helps you.
Regards,Alifur
