I Just would like to sharing how to use lightweight Dgeometry.
As you know that GC has vary geometry classes to support generating custom components. The good things is the Dgeometry is similar with Microstation and you are able to develop custom function with Microstation SDK if you are able to understand the generating workflow using the script.
I hope it will help you developing your skills and then please spread your knowledge with the other beginners.
Thanks.
