I recently generated Node Type out of a graph that I made. I noticed it was missing some input parameters necessary for it to function correctly. I fixed the code but would like to use the name of the Node I generated. I figured that it would be best if I delete the Node. Would anyone know how to delete a generated node?
Hello Samuel,
Please open Packager and from there delete the GNT that you want to delete and then it will be deleted from your file.
Hope this helps you.
Regards,Alifur
Answer Verified By: Samuel Aaron Felipe
Hi Alifur,Thank you for this. It worked.
