I've got a problem. I've created solids and I want to segregate them for two different levels. I prepared a list with string items (with two type of levels name) and I tried to connect nodes but it doesn't work. I made sure that there were the same number of items in both lists (Solids1 and functionCall7) but it doesn't work. What is wrong?Does this solid node works only when I've got one string item as an input?Adrian
Hello Adrian,
Can you please share the gct file with me for testing purposes.
Regards,Alifur
I made this file a little simpler - it should work without any excel external files. It works only if as a level name input is one string. If the list contains two elements then I got issue.
/cfs-file/__key/communityserver-discussions-components-files/360/Solids_5F00_to_5F00_differentLevels.dgn
If i understand correctly so you want to replicate the level data in each solid which comes from excels right? If yes then its a known issue where level names are not taking Replicatable values. There is a bug filed for this.
Exactly, I have thousands of solids and I need to sort them into several levels according to a list from excel data - this list will contain as many elements as solids. As in the screenshot above - in this example, there are two types of string data "Level_1" and "Level_2", but the length of both lists (Solids1 and functionCall7) is the same, but node doesn't work.Am I correct that this node only accepts one element in input as a level name? If so, I have to come up with another way.
Yes, the level name only takes one value and then populates them in all the solids. I would attach the bug with your SR.
Regards.Alifur
