Hi, I'm trying to recompile my CS functions, and my references look like this at the moment:
The last line is the important one, I'm importing Bentley.MicroStation, but the dll in the assemblies folder is bentley.MicroStation - this doesn't seem to cause a problem in visual studio.
When I try to run it in GC i get the following compiler error:
Which looks a bit fishy. Any idea what's going on?
If you want to see this in context, it is all here ethercodes.com/CKI0271QIV
If I comment out the reference to bentley.microstation, and the body of the NPgetSolarVector function, then it compiles
If anyone wants to pitch in and suggest a way to get this working then there is some karma available in it for you.
i checked a few of my projects and i have the same thing you do but the reference works fine for me. if i have a chance i will try to compile you code on my system.
Bentley.Microstation is a namespace used in assembly Assemblies\Bentley.MicroStation.dll. If you are using namespace Bentley.Microstation, be sure to reference this dll.
