How to programmatically assign an override template to a DTM?
Hi All,
I am attempting to write a simple utility to set the template override for a Terrain model element.
I've figured out how to access the EC attributes that set these properties but seem to be missing something.
If I apply a template override by hand through the properties dialog everything works as expected.
However, if I try and do it programattically it does not seem to apply the template ID. The Override Symbology flag is set successfully, however the template ID remains at -1.
My code is shown below:
	bool ECGetter::SetOverride()
		// Set scope to selected element
		FindInstancesScopePtr scope = FindInstancesScope::CreateScope(m_elem, FindInstancesScopeOption(DgnECHostType::Element));
		// Search through all classes on selected element
		ECQueryPtr query = ECQuery::CreateQuery(ECQUERY_PROCESS_SearchAllClasses);
		// Create EC instance iterator
		DgnECInstanceIterable iterable = Bentley::DgnPlatform::DgnECManager::GetManager().FindInstances(*scope, *query);
		WString classText;
		// Iterate through EC Class Instances
		for (DgnECInstanceIterable::const_iterator it = iterable.begin(); it != iterable.end(); ++it)
			DgnECInstancePtr instance = *it;
			ECN::ECClassCR instanceClass = instance->GetClass();
			// Check if we have a "CifDTMElement" ie OpenRoads Terrain
			if (instanceClass.GetName() == L"CifDTMElement")
				// Switch on override symboloy
				instance->SetValue(L"OverrideSymbology", ECValue(true));
				// Name of template I wish to apply
				WCharCP temp_path = L"Terrain Feature\\Existing\\E-Contours HATCH";
				ElementId tID;
				// See if we can retrieve an id for this template
				if (ETSTATUS_Success != ElementTemplateUtils::GetTemplateIDFromPath(&tID, temp_path, ACTIVEMODEL->GetDgnFileP()))
					// If no template id, see what dgnlib this template exists in
					DgnFileR TemplateDgnLibRef = *MstnElementTemplateMgr::GetDgnlibContainingTemplate(temp_path);
					// Get an ElementTemplateNodePtr for the template we want
					ElementTemplateNodePtr pTempl = ElementTemplateUtils::FindTemplateNodeByPath(temp_path, TemplateDgnLibRef);
					DgnFileR activeDGNRef = *ACTIVEMODEL->GetDgnFileP();
					// Copy the template from the dgnlib to the active file
					pTempl = MstnElementTemplateMgr::CopyTemplateToFile(*pTempl, activeDGNRef);
					// Commit template to active file (I think?)
					pTempl->ClearCachedInstances();
					pTempl->Write();
					pTempl->ReloadXAttributeData();
					// Retrieve the template ID of the newly copied template
					ElementTemplateUtils::GetTemplateIDFromPath(&tID, temp_path, ACTIVEMODEL->GetDgnFileP());
					instance->SetValue(L"WantMajorContours", ECValue(true));
					instance->SetValue(L"WantMinorContours", ECValue(true));
				// Set the "OSTemplate" attribute to the template ID
				instance->SetValue(L"OSTemplate", ECValue(static_cast<long long>(tID)));
		return true;
There is not a lot of documentation around about this, so I thought Id throw this out into the forum to see if anyone has any experience.
Any ideas why the above code may not be working?
Liam
Parents Reply Children
