SoftWare Version: ORD Update7
Operating System: windows10
Detail:
i create a dgnmodel in a ORD's design file. That is there is three dgnmodel in a dgn file,one is "Default-2D",another one is "Default-3D",and the last one is my own dgnmodel.
when i'm in my own dgnmodel which means my own dgnmodel is active. I want to get the ConsensusConnectionEdit in the Default-2D to create a TempalteDrop for corridor which is in the Default-2D dgnmodel, But i found that the ConsensusConnectionEdit only give two method to get a ConsensusConnectionEdit object, one is GetActive(), another one is GetFromRepositoryConnection(RepositoryConnection connect).
I have tried the ConsensusConnectionEdit.GetFromRepositoryConnection(RepositoryConnection connect) method, but found out that i can't create TemplateDrop correctly ,maybe i construct the RepositoryConnection object in a wrong way.
Can anyone help me to figure out how to add a TempalteDrop to a Corridor when the active dgnmodel is not default-2D/3D model but the Corridor is.
Any luck accomplishing this? I am struggling here too.
