In open-roads designer we are getting quantity based on style of feature definition. But most of the projects require quantity output as per components name wise. we may have so many components in a particular roadway section those components have common feature definition. In this case we are getting sum of all components volume instead of individual component wise. Can you please update program for individual component quantities extraction.
If we are assigning different feature definitions for those components for quantity purpose, it becomes difficult in production of visualization files.
Sasidhar
Hi Sasidhar,
You can customize an XSL Report to already do this. Look at XSL coding.
Mark
OpenRoads Designer 2023 | Microstation 2023.2 | ProjectWise 2023
Answer Verified By: sasidhar jagatha
Hi Mark, can you send me an example file of XSL coding to extract quantities of different components having same feature definition in templates?
Can you download the ORD ANZ (Australia & New Zealand) workspace? It has some Reports included in it that do this.
