User is unable to post to this forum, so I am posting on their behalf:
When trying to run a MVBA in PowerGeopak SS10 user gets an error message: "VBA interface error: unable to run macro - 0x80040552"
They are trying to run a LabelShapesWithID.MVBA which works well on Power GEOPAK SS4.
MVBA can be found here: https://bentley.sharefile.com/d-sd4d3b0f6a4c4252a
was this fix? I'm having the same issue
Hey Larry, Did you guys figure out the problem here?
colliersengineering.com
Yes, run this in your Command
Regsvr32 /u "C:\Program Files (x86)\Common Files\Bentley Shared\GEOPAK\08.11.09\BentleyControls.ocx"Regsvr32 "C:\Program Files (x86)\Common Files\Bentley Shared\GEOPAK\08.11.09\BentleyControls.ocx"
Thanks Larry... we figured out the issue (similar error)... apparently the user didn't have the FDOTSS10.smd file pathed in geopak drainage and caused a vba error.
