We have code that worked in Ss4 for Survey. We modified the VBA Annotations to read Element Templates as part of the command line arguments.
This is the VBA Macro code line that is used in ORD that worked in Ss4/OR
Survey,SHA0201,DrawAndLabel3dPipe,3D\Drainage\Pipe\Existing,Survey\Label\Storm Pipe,PINV,12
In the module and procedure that this runs, is a call to a label generating code. In it is a call to this code, where the error occurs. The purpose is to not only use the element template for its settings, but to make sure the text label that is generated has its template property set to match. We are able to set the active element template using the same text string, but we cannot set the newly create element so its Template property matches.
Public Function SetPropertyValue(ByRef oEl As Element, propertyName As String, propertyValue As String) As Boolean On Error GoTo Handle_Error Dim ph As PropertyHandler Set ph = CreatePropertyHandler(oEl) Dim accstr() As String accstr = ph.GetAccessStrings If ph.SelectByAccessString(propertyName) Then ph.SetValue propertyValue End If oEl.Rewrite SetPropertyValue = True Exit_Sub: Exit Function Handle_Error: LogError m_Module, "SetPropertyValue: " & propertyName & "=" & propertyValue GoTo Exit_Sub End Function
Here is an entry from the error log we write:
10/03/2019 11:32:20 AM CRheault SHAOHDPCEXXXXX [Survey]SHA 02.01.00 - SetPropertyValue: Template=Survey\Label\Sanitary ERROR -2147218366: Not available
Charles,
Could you write a new simple macro that tried to apply an element template to a newly created text element? Independent of Survey?
