how can I Create/Edit/Delete Surface Features using InRoads (081107566) SDK in Visual Studio 2015 C# on Windows 10 Pro.
Get the TerrainModel from your OpenRoads DTM. The TerrainModel object has functionality to add and delete points and features. You will need to add the Bentley.TerrainModelNET assembly.
thanks for the response. But not using OpenRoads, still using SS2.
you will find the Bentley.InRoads.Sdk.AT.chm helpfile within the
there are classes with some helpful methods
Frank
Thanks Frank,
Where would I find the reference to attach to use this namespace?
Sorry i can't see examples, too. Have you checked and tested the SDKManager class or the samples ...\InRoads Group V8.11\SDK\samples\VB6Samples\SDKExample?
