[ORD SDK] Need both VS2015 & VS2017 to get buildallexamples to work?
Hi all,
I've had issues getting the ORD SDK Examples to build in the SDK Developer Shell with Visual Studio 2017, getting unhandled exception errors in the bmake utility:
Once I installed Visual Studio 2015 as well it built all examples fine, although there were errors to do with long paths.
Interestingly, I tested with VS2015 only (with VS2017 uninstalled) and it ran into other errors (eg. framework). I found a similar post here: https://communities.bentley.com/products/programming/microstation_programming/f/microstation-programming---forum/176567/microstationsdk-update12---vs2017-professional/523338
Is there something wrong with my setup or an issue with the SDK? This also seems to be happening to some of my colleagues.
Mark
