Hey guys i was wondering if there was a VBA/macro that can search for specific dimension scale factos.
problem: so i have several drawings with scaled details and dimensions with appropriate scale factor but every so often i find a dimension that has the incorrect scale factor for that detail. at first glance its hard to tell whether the dimensions are correct. until you start adding dimension (manually)but is there was a vba or something that can highlight dimension with a scale factor or 2 for example that could be very helpful in checking that the dimension scale factors are correct for details that are scaled.
any help or suggestions would be appreciated
thanks
Hi Cristian,
Are looking to evaluate the annotation scale, distance scale, or something else?
Hey bruce thanks for replying, i think its call the "DIMSTYLESET SCALEFACTOR" i think what you called distance scale
Can I assume this is for Connect Edition?
primarily v8i (selectseries 3) - Version 08.11.09.578 but we also do use connect ed.
Here's a simple example of a tool that lists all the scale factors found in the active model with the number of dimension elements with each scale, and allows you to select the scales of interest and highlight the dimension elements matching those scales. I hope this helps...DimensionScaleCheck.mvba
