Over the last 5 years or so I've been using VBA to help us automate and standardise some of our processes, however I see that there is limited functionality/access for VBA in ORD; there seems to be a push to move toward using the SDK?
If that's correct, I just wanted to know what the best way forward is to transition from VBA to using the SDK:1. Is C# or C++ the preferred language (I'd need to start learning a new language). In our company we have both divisions that use both Bentley and Autodesk platforms for design so it would be good to go the route that could possibly service both platforms.2. Is Visual Studio the only IDE that is supported? Can I use visual studio Community? Ideally I'd like to test the waters in a free or open source environment first, and then motivate to purchase a licence for Visual Studio if that is the better development platform?3. Do I or my company need to be a part of the BDN or is that only for commercial development?
Lastly, as an intermediate, self-taught VBA user - how difficult is the transition? I know this is kind of like asking how long a piece of string is but it would be useful to hear others' stories that may be similar.
Thanks in advance for your help!
Chris
Hi Chris,
There are a few languages you can use, but C# seems to be the most documented with many examples, so this is the direction I'd go. There also should not be any issue using the free Community VS versions either.
Refer to a recent post on here regarding BDN. It should be free for current users, unless you want to use commercially.
Mark
OpenRoads Designer 2023 | Microstation 2023.2 | ProjectWise 2023
Thanks for the direction Mark! I'll explore the BDN more...
OpenRoads Designer 2020 R3 Update 9 (10.09.00.91) | Microstation PowerDraft v8i SS10 (08.11.09.912) | Previous MX User
