Hey Everybody,
I'm working in InRoads, and I'm trying to export data from an existing alignment report as a text file or print it. The vba code isn't much, it only brings up the Vertical Alignment page, but I can't seem to navigate and select "Save As", or Print.
Sub Geometrics()' Start a command CadInputQueue.SendCommand "inroadsgeometry reviewvertical" End Sub
I'd appreciate some help
Saul
Hi Saul,
I'm not clear what you're trying to do here, but it sounds like you could simply create a stylesheet to create the text file. What's the text file format you're after?
