I am working on the exporting geometry using the ORD SDK. I could successfully get the geometry of the model, using the ElementGraphicsProcessor
ParametricCellProcessor processor = new ParametricCellProcessor(); DgnModel model = Session.Instance.GetActiveDgnModel(); ModelElementsCollection elements = model.GetGraphicElements(); foreach (Element element in elements) { { ElementGraphicsOutput.Process(element, processor); } }
Separetely I export the Coridors with the corridors metadata, using the FindInstances method::
using (DgnECInstanceCollection instances = DgnECManager.Manager.FindInstances(scope, query)) { foreach (var instance in instances) { yield return instance; } }
The problem is that the Corridors are the IDgnECInstance's, while geometry are the Elements. The problem is that I could not link the Geometry Elements with the Corridor Instances. How can I get which Geometrt elements are related to the Corridor? Please advise.
Victor.
Hi Victor,
If I understand your goal correctly, this is the approach I would take using the ORD SDK's:
using Bentley.DgnPlatformNET;using Bentley.MstnPlatformNET;
using Bentley.CifNET.SDK;using Bentley.CifNET.GeometryModel.SDK;.
DgnModel activeModel = Session.Instance.GetActiveDgnModel();
using (ConsensusConnection conConn = new ConsensusConnection(activeModel)) { if (conConn != null) { GeometricModel sdkGeomModel = conConn.GetActiveGeometricModel(); if (sdkGeomModel != null) { foreach (Alignment alignment in sdkGeomModel.Alignments) { } foreach (Corridor corridor in sdkGeomModel.Corridors) { Alignment corrAlign = corridor.CorridorAlignment; } } } }
I hope this helps.
