I am trying to run the examples using buildallexamples.bat file. I come across the above error.
I am using VS2017 Professional on windows 10 64 bit
I dont have VS2015 on my computer . Should i also install 2015 version ? Any help is appreciated .
because your question is about OpenRoads Designer SDK (you did not mention this crucial information at all!), I recommend to move this question to Civil Programming forum. To move existing discussion to another forum, use More > Move tool available under your original post.
Also, please follow the best practices and provide all necessary information like version of product, version of SDK. I am not sure whether MicroStation + SDK has to be installed to use ORD SDK, but when yes, please also specify MicroStation + SDK version.
Jan
In UnmanagedSDKExample.mke file, replace BUILD_USING_VS2015 by BUILD_USING_VS2017.
