HOW DO I RUN THIS MACRO???
All i want to do is export my Levels to an XML so that i can import it as Element Template...
I cannot figure this out... PLEASE Help me
POWER GEOPAK V8i (SELECTseries 10) Ver. 08.11.09.918
The 'ReadMe.txt' file (in the OpenRoads version - I do not use GEOPAK) has the following:
DESCRIPTION:
This MicroStation Visual Basic Application is for creating an input XML file for Element Templates from all available levels.
USAGE:
1. Open the MicroStation file you wish to harvest the levels from to make Element Templates.2. Load the mvba project.3. Once the mvba project is loaded, run the included application within the mvba following the prompts to make an XML Element Template Input file.4. Import the XML file from within the Element Template dialog to create the Element Templates.
I believe it will only export levels in the actually DGN (or dgnlib) file. If the levels are coming from a level library only, they are skipped.
