One of the most common questions that I get is "what's the profile elevation at this station".
I haven't found the "magic bullet" tool in ORD to find this information. If there is no built-in tool to answer this question directly, I may need to build one. It doesn't help that I get to learn a new programming language (all I know is VBA, which is no longer supported).
I don't see any explicit methods or properties for this query. Does anyone have a suggestion where I might look, or a code snippet to give me a direction? Are there any particular functions that would be helpful?
Thank you.
Here are some code snippets. I may have went overboard on the comments. Hope it helps.
// A couple of namespaces you'll need at the top of your class // using Bentley.CifNET.GeometryModel.SDK; // using Bentley.CifNET.LinearGeometry; // Assuming you have an object reference to your profile; // I'll use 'myProfile', which is a type of Bentley.CifNET.GeometryModel.SDK.Profile // <Insert whatever code you need to get your profile> // A variable with your station in meters; double getElevStationMeters = StationMaster * 0.3048; // 731.52; // i.e. Sta 24+00.00 // Get a linearpoint object at the beginning of the vertical alignment LinearPoint profileStartPoint = myProfile.ProfileGeometry.StartPoint; // Oddly, the X-value of profileStartPoint is the distance from the // beginning of the horizontal to the beginning of the vertical // i.e. How far along the horizontal until your vertical begins double distBegHorizToBegVert = profileStartPoint.Coordinates.X; // So, we still need to know what station the horiz starts at. // And, be careful because if the alignment has no stationing, the // myProfile.Alignment.Stationing will be null and crash. // The line below will default to station 0.0 if Stationing is null. double horizStartPoint = myProfile.Alignment.Stationing?.StartStation ?? 0.0; // Now calculate the begin station of the profile double vertStaBegMeters = horizStartPoint + distBegHorizToBegVert; // Finally, calculate the distance from beginning horiz to our station point double distAlongMeters = getElevStationMeters - vertStaBegMeters; // ORD can calculate the profile elevation at the point your interested in using // GetPointAtDistanceOffset(distance, offset) // distance is the metric distance from the beginning station of the profile // offset is the vertical amount above/below the profile; typically you leave this // at zero to get the pgl elev. // Get a linear point from ORD at the distance along LinearPoint elev = myProfile.ProfileGeometry.GetPointAtDistanceOffset(distAlongMeters, 0); // The actual elevation is in the Y-coordinate of the linearpoint double elevMeters = elev.Coordinates.Y; // FYI: You can get a couple other values from the linearpoint double distBegHorizToOurStation = elev.Coordinates.X; double pglGradeAtStation = elev.TangentDirection; // Be sure to convert your values back from Metric to Master units
Oooh! I can't wait to take a good look at this. Thank you!
MaryB
Leaving this here for future use:
I'm going to suggest not using GetPointAtDistanceOffset as i noticed some slight discrepancies from my own calculations. Instead, I switched to GetPointAtX(distAlongFromStartHorizMeters).
So, more like so:
double stationMeters = dh.ConvertMasterToMeter(stationMaster); double horizStartStation = profile.Alignment.Stationing?.StartStation ?? 0.0; double distAlongFromStartHorizMeters = stationMeters - horizStartStation; LinearPoint elevPt = profile.ProfileGeometry.GetPointAtX(distAlongFromStartHorizMeters); double elevMeters = elevPt.Coordinates.Y; elevationMaster = dh.ConvertMeterToMaster(elevMeters);
