【C# ORDUpdate8】 templateLibrary load error
Hello:
When I use the following function  to load template library,exception occurs(length <0),while the paramerter “library path” is correct,which has been proved.
Other programmers in ChinaFirst forum also got the same problem,we didn't solve it yet.The Links are below:
https://communities.bentley.com/communities/other_communities/chinafirst/f/microstation-projectwise/202479/ord-c
https://communities.bentley.com/communities/other_communities/chinafirst/f/microstation-projectwise/211359/ord-c/640091
Hope this bug can be repaired. Thank you!
