Hi
I am working on a project (written in C#) that export OpenRoad model to other format.
I am getting the corridor from Bentley.CifNET.GeometryModel.SDK.Corridor, this corridor has start station at 374 and end station at 1865.
This corridor is attached to the alignment which has length 653 and its start station is 3048 and no station equation is defined.
It looks strange for me that the end station of corridor is over the alignment.
Could anyone explain me about the meaning of start-end station of corridor or direct me to the document/resources?
I'm using ORD & SDK version 10.09.00.91
Thank you
Hi Rattana,
please be aware this is general Developers and Programming forum. Because you question is specifically about ORD, I recommend to move your question to Civil Programming forum. To move existing thread to another forum (do not duplicate post, but move existing one), use More > Move tool, available under your original post.
Also, please follow the best practices and always specify used product including its exact version (e.g. build number), plus used API / language.
With regards,
Jan
