Is element ID (Bentley.DgnPlatformNET.ElementId) constant every time the model file is opened?
Is there other identifier to identify each element e.g. guid?
Thank you
ElementID for an element is constant for the model it is defined. If the element is copied to another model/file it may/will change.
