Hi all,
I am having issues trying to figure out how to scan reference attachments for Civil data, like Alignments. There is nothing I can find in the examples or any of the (limited) documentation.
Does anyone have a snippet they can share that does this? I can scan references using Microstation methods, just confused on how the ConsensusConnectionEdit/GeometricModel methods interact with this.
Mark
Here's a method we use, it will return a list of alignment objects of all alignments in the active model and reference models (note: the reference model needs to be visible to find alignments in the reference).
We are only looking for baseline & centerline alignments. Hope this helps.
public static List<Alignment> GetAlignments() { Dictionary<string, Alignment> alignmentDictionary = new Dictionary<string, Alignment>(); //Get all the civil models in the current dgn model BentleyCifNETSDK.ConsensusConnection sdkConnection = new BentleyCifNETSDK.ConsensusConnection(Session.Instance.GetActiveDgnModel()); List<GeometricModel> models = sdkConnection.GetAllGeometricModels().ToList(); foreach (GeometricModel geoModel in models) { foreach (Alignment alignment in geoModel.Alignments) { if (!alignmentDictionary.ContainsKey(alignment.Name)) { if (alignment.IsFinalElement && alignment.Name != string.Empty) { string featureName = alignment.FeatureName; //be sure alignment has not already been added from a different model and is either a baseline or centerline if (featureName.ToLower() == "alignment\\baseline" || featureName.ToLower() == "alignment\\centerline") { alignmentDictionary.Add(alignment.Name, alignment); } } } } } List<Alignment> alignments = new List<Alignment>(); foreach (KeyValuePair<string, Alignment> kvp in alignmentDictionary) { alignments.Add(kvp.Value); } return alignments; }
Answer Verified By: Mark Shamoun
Excellent - thanks Mike!
OpenRoads Designer 2021 R2 (10.10) | Microstation CE Update 16.3 | ProjectWise CE 3.4
Hi Mike Robertson,
I tried to use your code snippet to use collect the Alignment from the reference file and assigning it to point control in a corridor. but it does not work
editCr.CorridorEdit coredit = (editCr.CorridorEdit)cor; var profilese = AlignCol2[index].ActiveProfile; editCr.PointControlParameter pointControl = new editCr.PointControlParameter(AlignCol2[index], profilese, 0, cor.CorridorAlignment.LinearGeometry.Length, PointControlMode.Both, PointControlType.Alignment); pointControl.PointName = tableData.Rows[i]["Point"].ToString(); editCr.PointControlEdit addpoint = coredit.AddPointControl(pointControl);
when I run the code it work to create new pointcontrol, but under point control did not apply the alignment to the plan Element.
I am using Openroad Designer 10.09.0.91
Jason Tran
The original question was how to scan a reference for Alignments. Your question is about point control, you need to start a new thread if you haven't figured it out yet.
