Hi all,
I am trying to put some code together that requires an Object Space (of type Bentley.CifNET.Objects.IObjectspace).
Does anyone have an examples showing how this is done.
Mark
This is a part of the internal Bentley Civil API. It is not part of the Civil SDK and should not be used.
OK thanks David, does the SDK include Subsurface Drainage yet?
What I'm specifically trying to do is update all Node Catchments.
OpenRoads Designer 2023 | Microstation 2023.2 | ProjectWise 2023
Our ORD Subsurface SDK is minimal and only reads our data. It doesn’t create or modify data. I'm checking with the Haestad group to see if they have the catchment delineation functionality exposed in their API/SDK. I will let you know what I find out from them.
Hi Barry, any info you may have would be very helpful.
The Haestad dev group said this:"
We do have our WaterObjects api (and is available through BDN). It does allow read/write of data.
Users can create standalone applications, but it does not allow a user to extend (or change) functionality within our products."Also, we hope to have a command to update all the catchments attached to all the nodes in a selection set in 2021R2.
