[ORD 10.09 C#] example AlignmentEdit Null Exception
I'm trying to develop my own Alignment Import MDL addin.
I get a null exception, I've tried running the OpenRoadsDesignerCONNECTSDK example for ComplexAlignmentCreator
and get the same null exception in this line, AlignmentEdit al = AlignmentEdit.CreateByLinearElement(con, complexAlign, true);
Is there two points that this will work for?
Can anyone confirm if they also get the same behavior? ORD CE 2021 Release 1
Jon
