[ORD 10.09 C#] Obtain DgnModel Geographic Coordinate System (EPSG code)
I'm looking to get/set the Geographic Coordinate System from an OpenRoads/OpenRail dgn through the c# api as a part of a keyin command.
communities.bentley.com/.../616645
I've found in the microstation SDK forum a post such as this that looks helpful.
DgnModel activeModel = Session.Instance.GetActiveDgnModel();
DgnGCS cs = DgnGCS.FromModel(activeModel, true);
However, if I reference the Bentley.GeoCoord2.dll distributed with OpenRoads/OpenRail Connect Edition, the class DgnGCS isn't found from my searching.
Can someone please advise if this is possible or an alternative technique?
Jon
