I have an mdl app that runs fine in OpenBridge 10.9.x but I have now downloaded 10.10.0.85 and get an MethodAccess Exception.
This occurs when using the property BridgeAlignment in Alignments.
I tested the managed example code from the sdk, same thing occurs in the BridgeReporter method GenerateReport
Refer attached image. Can others replicate this? Is there a known problem or way to resolve?
I did reinstall as a check, and tried on several models (including upgrade of models from earlier version).
Jon
