ORD 10.10.01.03 - Hung up when setting element linestyle
3630.Jacobs-RailTools-Test.mvba
6354.Jacobs-RailTools-Test.dgnHi Team
I have created tools using mvba for a while, the tools are working fine in MS V8i and for first few version of ORD Connect.
But for later version of ORD, the macros just hung up when I try to set a linestyle of an element.
I am not sure if it is my system or a setting or an update from ORD that I miss, the function [Set elem.LineStyle = ActiveDesignFile.LineStyles("6")] is a basic function and it should not be an issue.
I am running ORD 10.10.01.03 (CE 2021 release 1) on Windows 10 platform.
Attached is a test mvba and a dgn file that I use, it is only a simple macros to draw lines from centre of view 1.
It is working as is, but when try to run the  [Set IniSCL.LineStyle = ActiveDesignFile.LineStyles("6")] then ORD will hung up, please try
Thanks in advance.
Tai Nguyen - Track Engineer - Jacobs
