Hi there,
I am trying to featurise a newly created corridor which I have created using code in c#. I want to featurise it however I am unsure how to do it. I have added
newCorridor.FeatureName = "Name";
but this still shows up as NotFeatured in the Open Roads dgn.
Any idea how can I acheive this?
Hi Rahul,
Rahul Vachhani said:I am trying to featurise a newly created corridor which I have created using code in c#.
Any discussion should be made based on shared code snippet, because from your question it is not clear how and using what API / classes you create the feature.
Rahul Vachhani said:I am unsure how to do it.
How do you create the feature? Using AlignmentEdit class or some similar (ProfileEdit...).
Did you check managed examples, delivered with ORD SDK?
With regards,
Jan
