Hi, Usually I get entities like alignments, corridors and terrains by accessing geometric model of an active DGN model:
var activeConnection = new ConsensusConnection(Session.Instance.GetActiveDgnModelRef()); var activeGeometricModel = activeConnection.GetActiveGeometricModel(); // access activeGeometricModel.Alignments & process alignments
But not all elements are not in a geometric model. For e.g., elements like BRep Cells or extrusion solids. But I can see them via GetGraphicElements() method of DgnModel.
I attached a DGN file. How can I get geometry data like surface area or volume of various elements? Which C# .NET API can help here?
3566.CBR71018_3D Model.dgn
请参考如下系列文章中的第28篇文章,看是否能帮助到您?
BTW, this is a Chinese programming support forum. If you like to use English to ask, Can you post your question on related English forum, such as Civil Programming Forum?
