Exporting Terrain Model
Hi
we have a localized xml standard for road models that is based on LandXML. That means the LandXML exported from ORD isn't applicable to our clients standards and we need to make our own work-intensive adjustments after exporting the terrain model.
I haven't found a way in OpenRoads Designer to export terrain models in xml with schema other than LandXML only by making changes to some setting in the software. Is the only way to try to create something with the SDK or could there be more of a lighter way to do this (maybe without the SDK)?
