Hi all,
Since upgrading to ORD 2021 R2 our VBA macros now have issues creating property handlers, especially for Complex elements with gaps in them - is anyone else seeing this?
Mark
not happening to anyone else?
OpenRoads Designer 2023 | Microstation 2023.2 | ProjectWise 2023
Hi Mark Shamoun,
This may be related to Bug 777794 having an internal fix committed in February.
Can you confirm if related between (internal) ORD versions if the same issue and addressed and file a new Bug if found different or not addressed?
Thank you and HTH,Bob
Hi Mark,
I have no code with PropertyHandler for ORD, but VBA in the last version (10.10.21.04) is broken for sure. I have VBA tool (not very complex, placing specific cell and filling attached tags), that works fine in MicroStation and older ORDs, but crashes completely the current ORD :-(
Jan
