[ORD 10.10 SDK] Get CorridorSurface directly from Selection set?
Hi all,
I'm trying to get CorridorSurface elements directly from a selection set. Can this be done?
It seems like the only way to get these is by scanning through the Corridor Surfaces and seeing that its base element is the same as any Mesh Header Elements that are in your selection, which is much less efficiency than i was hoping for.
Mark
OpenRoads Designer 2021 R2 (10.10)  |  Microstation CE Update 17 |  ProjectWise CE 3.4
