[ORLD 2021 R2 C#] Calculate alignments and plane (shape) intersections?
my situation is:
  • I have 3D model with referenced alignments, represented as 3D Linear Elements (result of Complex Element geometry and Profile definitions)
  • There are planes (defined using planar shapes)
So it is quite the same as model when sections (Named Boundaries) are created in ORLD, but question is different:
Every shape (because in general position) intersects zero, one or more alignments. What is recommended way how to calculate the intersections?
Without writing any test code, I see two options:
  • Obtain all LinearEntities3d > get LinearElement > use Intersect method (but it is not explained what parameters means, is it origin + normal?)
  • Convert MicroStation API element (CurveVector) and to use standard MicroStation tools to calculate intersection between curve and plain.
What is better, wrong, recommended?
With regards,
  Jan
