[ORLD 2021 R2 C#] How to find alignment (complex geometry) for 3D Linear Enitty?
in 3D model with sections, alignments are represented as 3D Linear Element objects.
They reside in referenced in 3D model. They represent 2D complex geometry plus defined profile. How it is possible to go from the entity (identified by file / model / id) to the geometry, to obtain the alignment?
I need to do some calculations for stationing in intersection between 3D Linear Element (representing alignment in 3D) and Named Boundary (representing section).
With regards,
  Jan
  • Hi Jan,
    Here is the sample code which might help your requirement:
    DgnModel dgnModel = Bentley.MstnPlatformNET.Session.Instance.GetActiveDgnModel();
    DgnModel activeModel = Session.Instance.GetActiveDgnModel();
    //get the elements from dgnModel
    ModelElementsCollection elements = dgnModel.GetElements();
    using (ConsensusConnection sdkCon = new Bentley.CifNET.SDK.ConsensusConnection(dgnModel))
    //Iterate over the elements
    foreach (Bentley.DgnPlatformNET.Elements.Element element in elements)
        //Check If current element is Graphics
        if (element.IsGraphics)
            Bentley.CifNET.GeometryModel.SDK.FeaturizedModelEntity fme = Bentley.CifNET.GeometryModel.SDK.FeaturizedModelEntity.CreateFromElement(sdkCon, element);
            //get objectkey for current element
            Bentley.CifNET.Objects.ObjectKey civilKey = Bentley.CifNET.Model.DataAccess.DgnPersistenceManager.GetInstance().ActiveConnection.GetECObjectKey(element);
            Bentley.CifNET.SDK.Edit.ConsensusConnectionEdit sdkConEdit = Bentley.CifNET.SDK.Edit.ConsensusConnectionEdit.GetActive();
            IObjectSpace sdkObjSpace = SDK.Edit.EditItemFactory.GetObjectSpace(sdkConEdit);
            if (civilKey == null || sdkObjSpace == null)
                continue;
            //get the GeometricEntity from the objectKey
            Bentley.CifNET.GeometryModel.GeometricEntity obj = sdkObjSpace.GetObject(civilKey) as Bentley.CifNET.GeometryModel.GeometricEntity;
            if (obj != null)
                if (fme != null)
                    if (string.IsNullOrWhiteSpace(fme.FeatureName))
                        continue;
                    try
                        Bentley.CifNET.GeometryModel.LinearEntity2dInPlan line2dEntity = obj as Bentley.CifNET.GeometryModel.LinearEntity2dInPlan;
                        Bentley.CifNET.GeometryModel.LinearEntity3d line3dEntity = obj as Bentley.CifNET.GeometryModel.LinearEntity3d;
                        if (line2dEntity != null)
                            if(line2dEntity.Geometry is LinearComplex)//Aligment
                        else if (line3dEntity != null)
                            if (line3dEntity.BaseGeometry is LinearComplex)//Aligment
                    catch (Exception ex)
                        string exception = ex.ToString();
  • Hi,
    thanks a lot for your code Thumbsup
    Meantime I found different solution / approach, where I start with GetAllGeometricModelsV2() method and I iterate the result. It provides information I need, but your code demonstrates some aspects that I maybe use in later steps in the code ;-)
    It would be nice to have documentation / explanation of concepts like keys, objectspace etc. To work with ORD SDK is like to play with black box with no documentation, hoping the right buttons are pushed in the right order...
    With regards,
      Jan
  • Hi Shasank,
    I have been trying out this code for a similar application, but cant find where "EditItemFactory" comes from?
    Mark
    OpenRoads Designer 2022 R1 (10.11)  |  Microstation CE Update 17.1 |  ProjectWise CE 3.4
  • You can find it in: Bentley.CifNET.SDK.Edit.EditItemFactory
    Try referring to:  Bentley.CifNET.SDK.Edit.4.0.dll
  • Excellent thanks. I didn't see it because i was using 10.10. Now available with the 10.11 SDK.
    Mark
