Hi there!
Does anybody know what is relation between Bentley.DgnPlatformNET.Elements.Element and Bentley.CifNET.LinearGeometry.LinearElement ?
In Alignment (Bentley.CifNET.GeometryModel.SDK.Alignment) are available individual LinearElements and I need temporary to highligt some of them, so it would be fine to have a reference to “normal” Elements.
After I published this post I came across this discussion, but unfortunately without clear solution.
Hi Stanislav,
What about getting the Alignment Element object using Alignment.Element and then check if it is a Complex element and get the subelements you want to highlight?
Mark
OpenRoads Designer 2023 | Microstation 2023.2 | ProjectWise 2023
