In C#, Using ElementCopyContext, I can copy TerrainModel to Terrain. Using C# API, can we change Terrain to TerrainModel? (In ORD, template’s endconditon cannot recognize the Terrain(copied)) Or is there a way to copy while preserving all properties of TerrainModel when copying?
please be aware this is general Developer and Programming Forum. Because your question looks to be about OpenRoads Designer, I recommend to move your question to Civil Programming forum. To move existing discussion to another forum, use More > Move tool, available under your first post.
Also, please follow the best practices and specify used product and its exact version (preferably using standardized subject format).
yjy 시미 유 said:I can copy TerrainModel to Terrain.
It would be better for discussion to share code what you do and also, because "terrain" is a bit generic name, to describe the problem in programming / API terminology. Now it is not clear whether the discussion is about "MicroStation level" (how to work with element handler, responsible for DTM) or with "civil model".
With regards,
Jan
