I have to convert a load of DWGs to DGNs
I have figured out how to do these in batches
I have started a batch process to do several changes to each file.
I am however stumped on a couple of the processes I would like to do.
I am a novice at best on programming and batch process.
I would like to create a Batch process that will:
1. Change Level Line Style to 0 if they are currently set to Continious. ( I am guessing I am needing to loop through the Levels?)
2. Rename Level 0 to Default and set it the current level.
Any help or suggestions would greatly appreciated
