Read complex chain, complex shape, cell.A complex chain consists of a header (type 12), followed by e.g. an arc (type 16) and a string line (type 4)In MicroStation V8i, each (sub) element own Element ID and a private Pos.In MicroStation CONNECT the Pos is always equal to the header element ..example:complex chain (12)Element ID: 474Connect: File = 0, Pos = 4000000V8i: File = 0, Pos = 4000000line string (4)Element ID: 475Connect: File = 0, Pos = 4000000V8i: File = 0, Pos = 4000001arc (16)Element ID: 476Connect: File = 0, Pos = 4000000V8i: File = 0, Pos = 4000002In CONNECT find the scanner MSSCANCRIT_RETURN_FILEPOS not partial elements:mdlScanCriteria_setReturnType (elmScan, MSSCANCRIT_RETURN_FILEPOS, FALSE, FALSE);A possible alternative to MSSCANCRIT_RETURN_UNIQUEID also does not work.mdlScanCriteria_setReturnType (scanCriteriaP, MSSCANCRIT_RETURN_FILEPOS, FALSE, TRUE);How to solve this?
