Scanning for elements in Navigator using vba
Hi there,
We have vba code that works perfectly with Microstation but we are unable to get it to work with Navigator.
The code is unable to detect any construction class elements using vba programming.
1. Place a block that has construction class into a design file and open with Navigator.
2. Run the code below to count the construction elements.
Regan
' Here is the code:
Public Sub ScanForBlocks() ' search for any existing Construction blocks
Dim oScan As New ElementScanCriteria
Dim oElEnum As ElementEnumerator
oScan.ExcludeAllClasses
oScan.ExcludeAllTypes
oScan.IncludeType msdElementTypeShape
oScan.IncludeClass msdElementClassConstruction
Set oElEnum = ActiveModelReference.Scan(oScan)
numConstructionBlocksFound = ProcessElementsC(oElEnum)
If numConstructionBlocksFound = 1 Then PlaceFenceFromConBlockPoints
End Sub
Private Function ProcessElementsC(oElEnum As ElementEnumerator) As Long 'returns number of blocks found
On Error Resume Next
Dim oEl As Element
ProcessElementsC = 0
While oElEnum.MoveNext
Set oEl = oElEnum.Current
ProcessElementsC = ProcessElementsC + 1 ' increment con blocks found
myPts = oEl.AsShapeElement.GetVertices 'store construction block points to place the fence later
Wend
Exit Function
err:
MsgBox "ProcessElements error #" & err.Number & vbCrLf & err.Description
End Function
