The high level question: Can Microstation v8i (select series 3) communicate with a web application that is running TLS 1.2 for it's security protocols?
What I have found is the following:
We have tried to "fake" Microstation out by updating some config files on the McLaren Software to point to the .NET 4.5.x Framework, but have not had any luck. Are there any other options that we have to get this configuration to work? Is there anything else to try that we may be missing?
I don't have control over the plug-in at this point but can work with the vendor (McLaren) on a resolution.
Thanks for any tips.
Nick
