With the issues between ProjectWise CONNECT and GEOPAK and InRoads, have you considered an update where the configurations are changed from $(CommonProgramFiles) to $(BC_COMMON_X86).
Update the configuration files:
geopak.cfgBentley Civil Assembly Location MS - Required.2.0.cfgBentley Civil MX Assemblies MS.cfgBentley Civil Roadway Design MS.cfg
geopak.3.1.cfgBentley Civil Assembly Location MS - Required.2.0.cfgBentley Civil MX Assemblies MS.cfg
%if defined (Load_GEOPAK_SS2)
%if !defined (_CONSOLEAPP)
#--------------------------------------------------------------------------------------## Common File Location for GEOPAK with ProjectWise CONNECT##--------------------------------------------------------------------------------------%if !defined (BC_COMMON_X86)BC_COMMON_X86 = C:\Program Files (x86)\Common Files\%endif
