Hi! Is there a Bentley SDK that can be used to convert laser scan files to the .pod format?
Kind regards, Jim.
Or possibly a command line tool even?
I didn't get the topic properly please explain clearly so that I can understand this. I take a help of Avast Support to solve this but this site didn't help me properly. Is it possible to refer me to a page related to this topic?
I have this question too: POD is a native point cloud format from Bentley. I understand, that there is an API for e.g. MicroStation to read this kind of files. Is there some kind of library that is independent from MicroStation to read/write POD files? For example to use this library in a desktop application outside of MicroStation.
Thanks in advance!
Hi Robin,
it's not good idea to extend 2 years old discussion, that was even about different topic :-(
I recommend to ask in a new post, maybe MicroStation Programming forum is better place where to ask, because it's more active than this very general forum.
As far as I know, no such independent SDK is published. But PointCloud API is a part of DgnPlatform API. It was discussed some time ago that this API exists independently from MicroStation, but is available based on agreement with Bentley only, not publicly. So maybe to contact BDN representatives directly makes sense in this case.
With regards,
Jan
