How to Change custom line style scale factor of a particular level from a reference file using VBA.
Below the code i used to change the override color: and it is working fine.
olev.OverrideColor = varcololev.UsingOverrideColor = Truedummyatta.Levels.Rewrite
I'm looking something like above code for change the scale.
I attached an image of manual process for easy understand of my requirement.
Hi Vinoth,
I assume there is no such method in VBA API available. In such case you have to use MDL function, I recommend to start with mdlLevel_setStyle. Please be aware it's just an idea based on documentation, I have no experience with this level sybmology settings.
With regards,
Jan
Thank you, Jan.
Vinoth Joseph
ATKINS
Bangalore, India
