I want to integrate .OST file with C#. I created a method where pass “File Path” & “File Name”. I want to read them with C# application. I have generated this code:
private static IEnumerable<mailitem> readPst(string pstFilePath, string pstName) { List<mailitem> mailItems = new List<mailitem>(); try { Microsoft.Office.Interop.Outlook.Application app = new Microsoft.Office.Interop.Outlook.Application(); NameSpace outlookNs = app.GetNamespace("MAPI"); // Add PST file (Outlook Data File) to Default Profile outlookNs.AddStore(pstFilePath); MAPIFolder rootFolder = outlookNs.Stores[pstName].GetRootFolder(); Folders subFolders = rootFolder.Folders; foreach (Folder folder in subFolders) { if (folder.Name == "Inbox") { Items items = folder.Items; foreach (object item in items) { if (item is MailItem) { MailItem mailItem = item as MailItem; mailItems.Add(mailItem); } } } } progressMaxVal =(int) mailItems.Count; } catch (System.Exception ex) { } return mailItems; }</mailitem></mailitem></mailitem>
After passing this code exception occur
“The Outlook data file (.pst) failed to load for this session.”
I have tried many methods to resolve this exception but all methods get failed. After wasting so much time on this error, finally I have submitted this exception on Codeguru forum but didn’t get any solution yet. After so many searches, I have found some useful forums where users also faced the same issue. I have reviewed these forums but can’t understand which one will fix this exception. Please suggest.
https://codepad.co/snippet/dyjIh4PQ
http://www.csharpforums.net/showthread.php/4254-Facing-Errors-while-opening-ost-file-in-C
https://www.stellarinfo.com/convert-ost-to-pst.php
http://p2p.wrox.com/c-2012-5-0-general-discussion/100067-facing-issue-while-opening-ost-file-c.html
Why are you asking about programming Microsoft products in the Bentley Systems programming Forum?
