ProjectWise SDK - Bentley IMS Login
I need to use the ProjectWise SDK (not the pwps_dab module) to login using Bentley IMS authentication. The documentation indicates 'aaApi_LoginWithSecurityToken' is the function but I'm not sure how to acquire the 'security token'. Does anyone have a working example they can share?
