I am a third party developer with no access to Bentley products. I would like to build an integration for ProjectWise using the Bentley Web Services Gateway REST APIs. Is there a playground that I am missing where I can get some keys and start building?
John Egan
Hi John,
I recommend to move your post to ProjectWise Programming forum, because this is general (no product specific), so it's less probable you will receive quick answer about ProjectWise issues here. In ProjectWise Programming forum, you can find discussions specifically about Web Services Gateway.
To move your post, use More > Move tool below your original post.
I also recommend to check Web Service Gateway wiki for some more information about the product.
John Egan said:I am a third party developer with no access to Bentley products.
I recommend to contact BDN team, because by default, an access to developers' licenses, SDK installations and documentation is through BDN membership.
John Egan said:Is there a playground that I am missing where I can get some keys and start building?
I am not familiar with the development for WSG, but I do not recall any such information. Maybe WSG instance is available in ProjectWise 365 service, but at least you have to have proper account and credentials. It's something I assume BDN team can help you with.
With regards,
Jan
