The version I have is last modified in 1998 and has to be added to the DEP on newer OS. Is it possible to get the source code so I can replicate the functionality in FME?
Hi Andrew Porohowski,
EdG.exe since MicroStation V8's release back in 2001 has long been deprecated and is only compatible with the MicroStation V7 (IGDS based) file format.Can you let me know a bit about the workflow, conditions and are constraints you need to work with so we can possibly provide a specific recommendation and help you forward?
Thank you,Bob
set search/status=active
open F:\Land\PERM\PERM.dgn
EDG F:\Land\PERM\pl08019.dgn
write wh
modify pbits = NOATTRIBUTE wh
SET DISPLAY /NOWORKING_UNITS
Exit
