Hi all!
We are working in a Railway project coming from OpenRail and we have to attach all IFC information using OpenBuilding Designer command Attach Instance Data using a specific Catalog we have developed.Since this process is quite repetitive, tedious and may lead to errors I would like to automize the process using VBA. The process requires:
1.- Filter elements by type (we do it through level in our case)
2.- Identify Catalog Item and select it
3.- Attach the instance to the filter elements
I have managed step one, and I am assuming that the Catalog Items are considered ItemTypes but I am struggeling to identify these and assign them to the different elements.
Does anyone have any advice for this?
Thank you all in advance,
Victor
