[Dev Portal] Remember mode setting
at first, I am not sure, what is the best place where to discuss ideas for Bentley Developer Portal. To Web Services (because it's web), to BDN forum (because it's BDN tool) or can be also here (which I prefer, because I hope it will motivate other people to think about possible enhancements).
I dislike to dark mode as default, especially when all other Bentley web use normal (white background) design.
And when it's the decision of somebody, it has to be remembered (at least in cookies). To have to switch off the black background every time I visit the web is really annoying.
With regards,
  Jan
  • Hi Jan,
    Thank you for your helpful feedback.  I will make sure this is added to the backlog of updates in progress.
    I am moving this post to the Developers and Programming Forum that is like a "general bucket" with full public visibility for issues that do not have an assigned and dedicated Programming Forum like existing: MicroStation, Civil, Geospatial and ProjectWise Programming forums.
    On that note, I will add a Developers and Programming Forum "Ideas" widget so we can provide a "Suggest a Change" on developer.bentley.com portal page.
    Again, thank you for your suggestion,
    HTH,
    Bob
    Answer Verified By: Jan Šlegr
